H22A JDM swap into 99 Lude.. Need help wont rev past 3000 rpm's
Discussion in 'Prelude' started by RaceTech, Aug 3, 2006.
  1. dickdanger
    dickdanger New Member
    yeah
    i have a 99 h22a swap in a 94 accord. the guy i bought it from did the full swap, vtec controller and what he called "the works", but the controller was stolen with everything that it was hooked up with. his "repair" was new wiring and a new ecu. but he put in a p13 j00. the car now limits at 4800. the reason why it does is becuase it needs a p5p L03 ecu. maybe that will give you a little insight. you have to research your engine and find the ecu for the year and model it came from.
  2. DESPAIN
    flower mound TX
    i think it might be your dizzy. my girls did the same thing and we put a new dizzy on worked like a charm. also make sure that the ecu is for a standard and not an auto ecu. let me know if this has helped
  3. Romi
    Romi New Member
    h22a2 won't rev past 3800 unless I unplug the tps and map sensors
  4. Romi
    Romi New Member
    Just did a swap da7
  5. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    you probably have some sensor plugs crossed up
