I would start with Intake 1 degree retarded, and the Exhaust 2 degrees advanced. I find this overlap gives nice midrange power without losing too much on the top or bottom. The higher you want it to make the power, the more I would take that setup and retard the cams. This is just a starting point of course, and be sure to check your timing after every change.
