okay i was reading some things about injectors. could it be that i am running the wrong ones. because of my civic having a ristor box does it need to run the saturated injectors instead of the peak hold ones of the integra.? ??????????
ok right now my car is runing on 3 pistons the number two piston is not firing if i unplug the spark plug wire it does not change anything. ok does anyone know how i can bi pass the ristor box on a 92 civic. or what do i have to do. ok i ran my car for 2 months with my swap. y did it mess up now!!!!!
I was pretty sure this was opposite. Remove the vacuum and the pressure rises; thats why a bad FPR will cause flooding.
Also, check for gas in the FPR vacuum hose, it is a sign the FPR diaphragm is ruptured
