Help!! Gsr in crx broken problems!
Discussion in 'Civic and CRX - EF' started by 90Rex, Oct 14, 2008.
  1. 90Rex
    90Rex New Member
    [​IMG]I RECENTLY BOUGHT A GSR SWAP OUT OF A CRX TO PUT IN MY CRX..
    GREAT DEAL ON WHOLE SWAP THE ONLY PROBLEM WAS..
    BROKEN MOTOR MOUNT BOLT THING ON THE BLOCK
    THE OTHER CRX WAS HIT BY A LIFTED TRUCK..
    I WAS THINKING OF TAKING IT TO A BUDDY OF MINE THAT WELDS
    ALUMINUM AND HAVING HIM FIX IT AND THEN RE TAP IT,
    THE BROKEN SIDE HAS ABOUT A 1/2 INCH OF THREAD LEFT..
    WHAT DO U SUGGEST PEOPLE?
    [​IMG][​IMG]
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ouch i dont know about that..you can try to fix it but i think its fucked
  3. dacheat
    dacheat ..is grounded.
    strongbadia
    oy. well your options are few :D
  4. xXxcaoticxXx
    xXxcaoticxXx ©aotic-©reations
    killeen texas
    had that problem with the half shaft mounts.scraped a nice block in ten feet after swaping it in
  5. 90Rex
    90Rex New Member
    ya tell me about it...
  6. efhondakid
    Akron-Canton, Ohio
    That can be fixed, but whats up with that timing belt? It doesnt look so good.
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    omg wtf?!?!? 2??
  8. xXxcaoticxXx
    killeen texas
    theres one on right and one on backwards from were i sit.wtf is with that?
  9. 90Rex
    90Rex New Member
    the piece from the block fell down on the adjuster and shredded the timing belt
    then the belt overlapped it self...
    i got a new belt.
    gsr water pump
    and oil pump..
    cause it was sitting for a while
    when i got it from the dude
  10. xXxcaoticxXx
    killeen texas
    you take off the valve cover to chk the valves yet?..or even better take off the head and chk everything?you could have a lot more money going into this bad boy than you thought
  11. efhondakid
    Akron-Canton, Ohio
    Yeah that motor is junk, Im can almost garantee you bent some valves when the timing belt let go.
  12. 90Rex
    90Rex New Member
    well it diddnt let go or skip teeth theres still a good portion of belt on the other side, the belt split in half more than shredded.
    but if thats the case no biggy
    i hava a p72 head with new seals just sitting in my room!
    i was going to build a b20v
    thats why i have all kinds of parts..
    i got a pr3 ecu 2!
  13. xXxcaoticxXx
    killeen texas
    not for sure on that.but it depends.. if you chk it all out it could be fine...but make sure you chk it out befor it goes in it will make life simple.you should be able to see valve damage with just the valve cover off.but to be safe i would take off the head. thats up to you though. could have contacted the valves and dinged a piston could have spun a rod(not likely) who knows
  14. 90Rex
    90Rex New Member
    im gonna pop it off in a lil while..
    see whats going on in there...
    hopefully its all good..
  15. efhondakid
    Akron-Canton, Ohio
    I would definitly check it out before you put it back in the car, you may have some serious damage internally.
    And how much for that ECU shipped to 44685?
  16. xXxcaoticxXx
    killeen texas
    226 shipped 2 day there
  17. 90Rex
    90Rex New Member
    ya im going 2...
    let me get back with u tomorrow on that...
    i gotta check..
    im in california!
    so ill pm u tomorrow
  18. efhondakid
    Akron-Canton, Ohio
    Ill just keep runnig the PR4 in it for that price.
  19. 90Rex
    90Rex New Member
    dont listen to that dude...
    ill hit u up tomorrow,.,.,
    it wont be anywhere near that..
  20. 90Rex
    90Rex New Member
