Help me! new motor!
Discussion in 'Prelude' started by Lude182, Feb 11, 2009.
  1. Lude182
    Lude182 New Member
    ok so i will be buyin an 89 lude with 4ws. the b20a ive heard is a bastard. i was wonderin wat i could swap this with? wats easiest? an h22 would be nice but out of the question on my bugdet. help any suggestions??:confused:
  2. Lude182
    Lude182 New Member
    please help ive heard b20a is good for boostin. is this true? any advice can help
  3. BrutalB83
    Rochester Hills, MI
    Nothing besides other Prelude engines from that generation are going to be an easy swap. You can do an H22 with swap mounts, but it will be expensive still...
  4. nootrac22
    exeter pa
    right the way the car sits and how low the hoodline is there's nothing easy to fit in there.
  5. MthaFuknGreen
    Lodi, CA
    those two posts contradict each other.
    and the b20 is actually the better engine out of the two offered stock in 3rd gens based on majorities opinion.
    mounts for the h22 are readily available for 3rd gens.
    only 475 plus shipping.
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    That's not exactly cheap for someone on a budget.
    Any motor can be boosted. What are your power goals?
  7. MthaFuknGreen
    Lodi, CA
    they are az racing mounts i believe.
  8. BrutalB83
    Rochester Hills, MI
    Your point? Just because you can buy a mount kit for X amount of money doesn't mean it's a drop-in swap or that it won't be expensive, which is EXACTLY what I said in the first place, was it not?
  9. MthaFuknGreen
    Lodi, CA
    i thought you were implying that custom mounts are needed.
  10. BrutalB83
    Rochester Hills, MI
    Nah, just saying that an H22 is an expensive and not quite bolt-in swap for a 3g Prelude. If he's looking for something that is going to drop in and bolt up, then he needs to stick with the B20A/B21...
  11. MthaFuknGreen
    Lodi, CA
    im gonna save 4-5k for my h22 swap.
    thats including mounts, axles and an h22 type s.
