help me please anyone
Discussion in 'HYBRID -> EG-EK / DC' started by 97hatchdx, Sep 2, 2008.
  1. 97hatchdx
    97hatchdx New Member
    okay so what i did was swap a different y7 head on my y7 block because the other one had a bad lifter. well i try to start the car and it idles at like 100 and when you floor it, after 10 sec or so it revs up but i noticed alot of smoke comes out if above like 3000[grey colored] maybe because it was flooding? i changed the oil and coolant..
    could it be my timing is off?
    also, when it rev's it doesnt sound like it should
    i never took any wires off the dizzy so its not firing order.
  2. efhondakid
    Akron-Canton, Ohio
    Timing, and grey/white smoke is a blown head gasket/cracked head. And hondas dont have lifters.
  3. 97hatchdx
    i installed the headgasket. i did everything and torqued it down to specs. i did it 4 times in sequential order. so i dont understand how it could be that
    could the timing be off and the headgasket is fine?
  4. 97hatchdx
  5. 97hatchdx
  6. |Chaz|
    |Chaz| Well-Known Member VIP
    Dude didn't you read a manual before you started taking shit apart?
  7. 97hatchdx
    yes i read the manual and thats why i cant figure out what went wrong.
    you think its from air injection on the manifold?
  8. efhondakid
    Akron-Canton, Ohio
    If you have white/grey smoke that means your burning coolant, bottom line. Either the head is cracked or warped or you may have a bad intake manifold gasket (altough Ive never seen that as being the case on a Honda)
