teamflorida AJ
ok i have a 88 crx witha zc in it. The car did run. it does have power to coil but wont fire over. the main relay clicks the clicks again 2 seconds later . now i have a 87 si that did have a problem with the relay before . but th0042 relay is not the same as the 0063 in the 88 crxsi. now car when it ran last acted like it ran outta gas. the died while idling. the 0063 relay worked in the 87. Now i have ckecked for grounds near the distributor. and have found no loose wires even looked a junk yard cars and see no wires for grounds near the distributor. only near the rear of motor.where all grounds come to one spot. Thanks for any help !!
