byebyebaby
Byaaah!
ok i have a 91 dx hatch with a d16y5 swapped in it thats boosted, now everything has been fine for about a year now but as of late the car has a hard time idling and i can smell raw gas when it does idle. im looked high and low and found no fuel leaks. im starting to think that it may be my iac valve because when it does stay running it steadily rises and falls between 500-1100 rpms but im not sure if that will make it run pig rich. also when im driving if i hit the throttle too fast it will cut out for a sec or two then pick up. im thinking its either the iac valve, bad grounds, a faulty chip which im gonna reburn here in a minute, or worst case scenario the ecu itself. oh yeah im using a pm6
