high pitch whine in all gears
Discussion in 'HYBRID -> EG-EK / DC' started by Pvtjoker122, Jun 23, 2009.
  1. Pvtjoker122
    Pvtjoker122 New Member
    San Diego, CA
    I've got a 92 Civic hatchback with a GSR swap, and ever since I've had the car it has had a high pitch whine while accelerating. I've had the car for about 4 months now, and I thought it could be something in the tranny, but then I swapped the tranny from the 93 GSR tranny which was in it, to an LS tranny with a GSR final drive, and it still had the same noise. I also have a Quaife LSD which I had in both trannys, I thought maybe it was some kind of whine coming from the LSD, but my mechanic said he has ran those for a while and that they shouldn't make any noise. My mechanic also mentioned it could be wheel bearings. Any other ideas?
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    You make sure it's probably filled with fluid?
  3. Pvtjoker122
    San Diego, CA
  4. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    Hey do you have a streo with an external amplifier. I have this problem or somthing like it. Try a new alternator and or battery.
  5. Pvtjoker122
    San Diego, CA
    No, I don't think it's anything electrical. It's more pronounced as I increase speed. Kinda sounds like it's coming somewhere from the drivetrain.
  6. werdupEGs
    werdupEGs New Member
    HSV, AL
    Got a supercharger on it?
    Maybe powersteering (if you have it). I had a couple cars that did that and it was the powersteering pump.
    The miata did it too but it was the differential.
  7. Jared759
    Jared759 Well-Known Member VIP
    SC
    Alternator speeds up when you increase speed.
  8. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    check your gear oil level and if not that its probably waterpump ,alternator ,or belts.one of these may be your problem...
  9. Magana559
    Magana559 The Warden
    fresno Ca
    can you record the sound?
    also try reving the engine when the wheels arent moving. if these is no sound then it just might be the wheel bearings.
  10. Pvtjoker122
    San Diego, CA
    Yes, but the sound is proportional to wheel speed, not engine speed. Like I said, the higher my speed is the louder and more pronounced it is, and it's only when I'm in gear.
  11. Pvtjoker122
    San Diego, CA
    Lmao, nope, no supercharger. No power steering either.
  12. K2e2vin
    Raleigh, NC
    Until it comes out of the fill hole.
    Does the whining sound similar to reverse gear?
  13. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Throw out bearing?
    This guy needs to narrow down the noise if he thinks he's gonna get any help on here. Guys are all over the damn car.....Stereo? Alternator? Fluid in Trans? Blah blah blah
    NARROW IT DOWN. PUSH THE CLUTCH IN....DOES IT GO AWAY? Is the sound based on tire speed or motor rpm? Are all things that dont need to be on turned off. Does it do it louder in first....fifth...etc.......GIVE MORE INFO....use your words!
  14. Pvtjoker122
    San Diego, CA
    I'm pretty sure I have narrowed down everything that you have mentioned, read the rest of the replies. Now, as I said before, it is only when the car is MOVING, and when I'm IN GEAR. Do I really need to say all this again? Anyway, it becomes a higher pitch as my speed increases, and only when there's load on it (when I accelerate). Let me know if there's any more info you need, but don't be an ass about it. Thanks. And no, I do not have a supercharger.
  15. K2e2vin
    Raleigh, NC
    When you swapped the LSD, did you swap the final drive too? If so, how did the teeth on the gears look? It could also be the differential bearing too though.
  16. CAFROG
    NOR-CAL
  17. Pvtjoker122
    San Diego, CA
    Yea, everything was different. Hmm, well, I hope it's not a bearing somewhere in the tranny. I guess I'll check out the wheel bearings too though. Thanks for the help.
  18. K2e2vin
    Raleigh, NC
    I want to say it's not the bearings; as those would make noise all the time or when turning(wheel bearing).
    Since it's happening on both transmissions though; only bearings that are the same is the differential and wheel bearing though. I say check the fluid because you're supposed to fill it until it overflows out of the side fill hole; when my transmission was leaking fluid and got low you can actually hear slight whine just as you're describing. The sound has got to be from the gears meshing.
    Also, what brand/viscosity fluid did you use?
  19. Pvtjoker122
    San Diego, CA
    I'm using GM Synchromesh, 3 quarts.
  20. K2e2vin
    Raleigh, NC
    That's what I was using too but refilled with regular 10w-30. You think you can try Honda MTF or at least draining some of the fluid and filling the rest with regular 10w-30 oil?
