How are these endlinks supposed to work?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by SlowEgg, Aug 21, 2006.
  1. SlowEgg
    SlowEgg I need paint.
    Omaha, NE
    It says they are for 1988-2000 Civic, and 1990-2001 Integra. I just dont understand how they will work. Which end fits into the sway bar, and which fits into the control arm?
  2. TurboMirage
    those are for the front im assuming?
    doesnt matter. they are the same top and bottom. fit the control arm between the bottom two red bushes and the sway bar between the two two bushes.
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    :werd:
    But those kits hardly ever actually fit.
  4. SlowEgg
    Omaha, NE
    They are supposedly for the rear. They do look alot like the fronts though. If they are the rear, there needs to be a "stud" that goes front to back (for the LCA), and one that goes to the side (for the sway bar). All resources indicate, however, that these are for the rear. They "should" look like this:
  5. GSRCRXsi
    MD
    the first pic is for the front, the second pic is for the rear
  6. SlowEgg
    Omaha, NE
    Thanks man. It's just confusing when sellers (mainly on Ebay) label them wrong.
  7. Ryma
    Ryma Member
    evilbay is evil stay away no matter how the deal sounds.
    Remember if it sounds to good to be true its generally bad.
  8. TurboMirage
    my GSR rear endlinks dont look like that.
