How do I know what engine will fit?
Discussion in 'Civic and CRX - EF' started by east_bay_ed, Jul 24, 2008.
  1. east_bay_ed
    east_bay_ed New Member
    Hi I'm new to this forum thing. I don't know much about it, let alone how to use it.
    I just want to know if a D15B7 motor will fit in a 1991 honda civic si (hb)?
    I think my head gasket blew and I was given a motor, but I don't know if it'll fit.
    I know it came out of a Civic ( about a '94) . I hope it does fit cause I'm tight on money before school starts.
    1 person likes this.
  2. east_bay_ed
    Anything?
    Well thanks for the response.
    What I'm tryin' to do is go the cheapest route. With the least amount of work I should say. without havin' to put a new computer, drive axle,Etc.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    then the only one is the stock motor
  4. east_bay_ed
    What would I extra work would i have to perform to make this engine work?
  5. AHHVTEC
    Alabama
    nope just doing it
  6. east_bay_ed
    So, no changing out the motor mounts? and everything will hook right up? I'll probly be doing all this on my own, so I'm tryin' to get as much info as I can.
  7. inthava
    inthava New Member
    d15 will fit your 91 si
  8. east_bay_ed
    Tight! I wish I could afford a VTEC but moneys tight right now. thanks for the advice. Just need my runner up and going for now. I've been driving a chevy truck that has been eating up my money at the pump.
  9. Justin91civic
    Justin91civic New Member
    Nashville, Tn
    Ok so no one has said this yet I thought that I would let you know. The d15b7 is a obd1 motor so if you want to use that you will have to get a conversion harness to go from obd-0 to obd-1 if you would like to stick with obd-0 then you would have to get a obd-0 dizzy out of a d16 that is from a obd-0 car.
  10. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    he can use the intake manifold and distributor from his car.
    if you've blown your head gasket, why not sell the D15 and replace your head gasket and timing belt? you will end up with a much better engine and learn more about working on engines that way.
    helms manuals are availiable for download free or pick up even a chilton's manual for $20 it just involves some reading and carefully following instructions.
    anyway good luck, and dont forget to have fun.
  11. east_bay_ed
    I would try to do all this on my own, but I'm on a cramped with time right now before school starts. I'm takin my family on vacation. Otherwise I am the type of person to try to dismantle and rebuild. Besides, the "SI" I have has a salvage title. So i don't want to dump money into it if I have to sale it one day, and nobodys interested because of the title.
  12. Parrish36
    Parrish36 New Member
    hey i know someone thats got a D15A3 that he would sell ya bored 0.60 over forged pistons shaved head custom $800 cam, custom intake with a holley 500 bolted on, advanced timing adjustable gears, bigger valves and springs, header, moroso oil pan, it won the mini stock championship in 2006. i think he wants 3 G's, but its a rocket of a motor turnin about 11000 RPMs. wanna buy it?????
  13. AHHVTEC
    Alabama
  14. east_bay_ed
    riiiiiight. I'll pass.
  15. 1sikef
    1sikef New Member
    if you put the b7 in your hatch all you got to do is use your tranny, axles, and dizzy that sall you got to change is so easy whats wrong with your stock D16a6
  16. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ^ blown head gasket...which are easy to replace..takes me about and hour to pull the head and replace the gasket,then put it back on
  17. east_bay_ed
    About an hour? I might try that. But don't you have to do the timing when you pull the head?
  18. SLOWdelawareEG
    SLOWdelawareEG my cars go fast
    hilton head island, sc
    yup. but if you can handle doing the head gasket by following a manual, you can do a timing belt just as easy;)
  19. east_bay_ed
    right on. I'ma givita' try
  20. drummingpariah
    drummingpariah Author of the Madness Man
    Bay Area, CA
    +/- one weekend, depending on how mechanically inclined you are.
    In all seriousness, it's pretty straightforward. Get an accurate, quality torque wrench and a service manual (along with a standard socket set) and you should be golden.
