how many gallons of paint will in need
Discussion in 'Body / Exterior / Interior / Cosmetics' started by 95preludetypes, Sep 4, 2004.
  1. 95preludetypes
    95preludetypes Member
    im going to paint my 95 prelude. i was wondering anyone knew how many gallons i would need. i wont be painting the hood or jamms ect. im going to use acrylic enamel and clear thank you.
  2. ssl2k
    ssl2k Senior Member
    2-3 quarts primer and all the othe rshit ya need to mix it rgiht, then 2 quarts paint and a galolon of clear and you'll beable to do it good
  3. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    you don't need a gallon of clear 2 quarts of good clear will be enough for 3-4 coats
  4. ssl2k
    ssl2k Senior Member
    shit
    yeah sorry i was tired
    2 quarts like hcivic said fa sho =]
  5. 40_below
    40_below Junior Member
    Umm I don't know about only 2 quarts of clear.. I would go at least 3 quarts (reduced)
    And if you're using single stage paint as basecoat you are going to need to let it dry completely, wetsand it, and then clear it.
  6. hcivic.com
    ya dude i mean 2 clean qaurta un mixed
  7. driver1
    driver1 Senior Member
    i wouldnt even bother trying to paint it without ATLEAST 2 quarts of unmixed clearcoat....if not about the tiem you get 3/4 of the way through your second coat of clear and you run out....your gonna be one pissed off motherfucker
  8. hcivic.com
    i have never heard of buying a premixed clear either?
  9. driver1
    no, you cannot buy it already mixed, but there is a difference between a sprayable gallon and just a gallon of clearcoat
  10. hcivic.com
    i know that but i don't think 40 does. I have seen spryable paint and primer.
