I was wonder how much it would cost to resleeve or sleeve a b18b. I want it so that when i go turbo the block won't crack. If you could give me an estimate that would be great. Thanks for the help.
1200 bucks or so installed...
but then you have to bore/hone it to your piston size.... and if you go larger, like to 84mm, you need new pistons of that diameter
