Originally posted by civiclxb16@Apr 8 2005, 03:38 PM
well i put the new injectors in and still nothing now here is the wierd part. i put a set of lock pliers on the fuel return line and it started ran pretty bad but it started what could that mean? i am going to put the fuel pump in now let me know
[post=484821]Quoted post[/post]
Originally posted by ksrcivic@Apr 9 2005, 07:58 PM
im telling u that ur injectors are not firing... like i said before check for 12 volt at the black yellow wire, if u have then its in the injector wires going back to the ecu. just try what I am sayin its not hard.
[post=485210]Quoted post[/post]
Originally posted by civiclxb16@Apr 8 2005, 04:26 AM
so if it is a wiring problem what should i look out for i mean everything was working what could of caused the short?.....
Originally posted by da9driver@Apr 10 2005, 08:31 PM
have you tried putting in a different fuel pressure regulator. if there is not enough fuel pressure in the rail the injectors wont fire. so when you pinched the return line you raised the pressure but not enough to get the car running right. check it with a known good regulator and if that doesn't work then replace the fuel pump.
[post=485484]Quoted post[/post]
Originally posted by CiViChAtChBaCkMn@Apr 11 2005, 08:09 PM
is ur starter good?
battery good are u getting electricity?
alternator any good did u cheak ur fuses?
do u have oil in your car?
is ur motor wired corectly?
answer these questons and ill get back to u were are u living?
i had a few cars wit simalar problems
what kinda fuel regulator u got?
is it clogged
someone might have put sand in ur gas tank ur motor is prolly fried....
drain your oil and see if there is anything bad in your oil
also when u drain the oil look for coolant
check your coolant levels
maybee headgasket problem or you motor isnt being cooled....
[post=485870]Quoted post[/post]
