Domeskilla
Originally posted by 94Civintegra@Mar 21 2003, 01:35 AM
Well Im going to be daily driving this car, so I'd like to keep it a gas station car, and when I read your Articles it said that a boosted car for daily driving is always better then a N/A car because the N/A car would (using math in the article) need like 15:1 compression ratio.
And if I use boost I can still not completely eat away at my MPG because from what I learned from the boost articles, the more exhaust you have comming out, the more gain your going to see... so I think that means if I drive it normal, I'll get closer to normal MPG, but Ill have the boost when I race. And I believe its a lot cheaper.
Im definetely going to stay with the boost.
Is it possible to get 13's with 8000? If its not, what is possible? And how can I get it?
You dont need 15.1 CR. You can do it on far less. Jason is laying down 191whp on 11.6 i think it is and Calesta put down 185whp on 12.6 CR on pump gas.
You run pump gas on anything streetable, its all in the tuning. NA car you will need a more aggressive cam's, CR, tighter tranny, etc. You will lose gas mileage, but hey.. you want performance, gas mileage goes bye bye.
You can go boost, and if you do.. get an LS motor and boost it. Cheaper to tune and will go 13's for not as much money as a vtec/turbo setup would take (b16, gsr, itr motors)...
Boost gets good gas mileage, b/c you can stay under boost, but you will still give up on mileage.
