and to tell if they are obd1 or obd2 is the little tab that is where the clip is. if the tab is right in the middle, it is obd1 if it is off center slightly it is obd2
I did not find anything in the faq but flow rates. I am needing this info because I just bought some injectors from a 92-96 prelude (supposed to be) for my h22a4 swap in my accord. It is still leaning out with these injectors lke it was with the stock accord injectors(240's)
All Acura/Honda's before 1992 use Peak & Hold style injectors. These are low resistance injectors that are measured at 2.5/3 ohms(measured at 43 P.S.I.G).
Acura/Honda's from 1992 and newer(with the exception of 92-96 Preludes) use Saturated injectors. These are high resistance injectors that are measured approx. at 12-16 ohms (measured at 43 P.S.I.G).
Originally posted by csan@Nov 13 2003, 10:15 PM Ok I understand all of that but how do I know if I got peak and hold 240cc or peak and hold 345cc like I need
send them to rc engineering, they'll flow test them
well, the 96+preludes have the 240 cc saturated, it looks like the only obd1 injectors were the 340cc prelude peak hold injectors.
