94GSRB20swap
I am reposting in this forum hoping to find better answers here.
i own a 94 acura integra GSR. i blew the engine and bought a B20b 99-00.
before i dropped it in i touched nothing in the car. except the harness for the engine which needed the obd2 plugs put on.
it ran fine with some minor issues like misfire and running a little offtime... but it ran up to 8000 fine then. i ventured for a non vtec ecu, and bought a p06. when i took out the p72 and replaced it with the p06 it idled smoother but when i reved up the engine it was way worse. i drove it for a bit and it was terrible, but still the rpms would climb. i then replaced it with the original ecu and since it will only rev up to 3500.
i sent the p06 to phearable.net for chipping. they tested and sent it back no problems.
i plug that in and it still runs only up to 3500K. either ecu does this now and im LOST!!
any idea what might be causing my engine to hit a rev limiter?
my 2 step rev limiter on the chipped ecu is 4300 and my spedometer works.
please help!
throwing code 14- IAC valve. thats the only one.
please help!
