delsolsir2
I have a 93 del sol S that im swapping a jdm b16a into. I installed a wiring harness from a obd1 gsr integra, to add the wires to the knock,vtec,oil p. on the engine. However the problem that im having now is that the larger plug on both the drivers and passanger side do not fit with what is in the engine bay. I realize that i have extra wires on the integra harness (evap, intake butterfly, map), but the connectors look like with slight mod, i can get them to fit. I dont know if everything will be hooked up though. do i have to repin the conector? I dont want to splice into harness. All other plugs fit except those two, any help would be appreciated.
