internal vs. external
Discussion in 'Forced Induction' started by sevenhillsbilly, Apr 10, 2008.
  1. sevenhillsbilly
    sevenhillsbilly New Member
    which would you reccomned on a t3/t4 or a t25
    an internal waste gate or just take it off and run an external wastegate?
  2. Briansol
    it certainly depends on your goal for the car.
    you can't just 'take off' an internally gated turbo and call it a day either....
  3. sevenhillsbilly
    well obviously you cant just take it off its a little more indepth than that but
    which would you prefer
  4. SLOWdelawareEG
    SLOWdelawareEG my cars go fast
    hilton head island, sc
    that really depends on the application, personal preference, and what kind of boost you want to run. i prefer external simply because you have the option of changing the spring to suit your needs. need 2bar? no problem swap the spring. also, it can give you an easier and larger range of operation. for example, my civic(when i finally get it done) will run a super light spring--0.25bar(3.6psi)-- and will use an electronic boost controller in the setup(apexi avc-r). that way, i'll have nice low boost for city driving with the capability of going as high as its tuned for on the fly
  5. sevenhillsbilly
    oookk that explains it thanks
