Is 94 accord crankshaft pully bolt reverse threaded?
laffinfish
I'm trying to remove the crankshaft pully bolt but it won't come off, not even with an impact wrench. Maybe I'm turning it the wrong direction. To remove bolt is it CW or CCW? Please help... Thank you
Laffinfish
I have an 89 Accord and I have the same problem. The only way I can see to get it out is an 6 foot cheater bar and impact grade socket!!! I just can't figure out how to keep the crank from moving..... GRRRRRRRR!!!!
snap-on is your problem solver. Turn your air up to about 120 psi and let it rip
A strong breaker bar, a stronger socket and a 5-foot cheater bar are necessary. Put the car on the ground, and put it in 5th. You'll probably need to find a way to keep the crank from rotating as well.
A few shots of PB Blaster a few hours before start couldn't hurt either.
