J32A2 swap into 97 or 98 Accord...
DriverMP
I would like to know what car is better ( less complicated ) to perform the J32A2 motor swap into.....keeping in mind that both Accords would be the V6 models and that the swap is with a shifttronic tranny...
P.S J32A2 = Acura 3.2 TL type-s engine 1999-2003
thanks
I haven't seen that swap done. I think the Accord V6 is a C series, correct? You would need to find out which motor if any lines up in those mounts. I don't know, so I won't advise you.
thank's tab,
I've seen it done on both cars but i have no more info about it, all i know is that it can be done, but then again anything can be done with enough money.....
I'll check it out!
Got it.... V6 Accord 98-02 = J30A1.....i guess its J series
95-97 = C27A........ C series
