JDM D15B Vtec into 93 fodo
if you cant wire it like i couldnt get it to work the engine will still work plugged into that ecu so just plug it in and drive it to your local performance shop and have them do it it only cost me like 70 bucks bringing the total of my mini me swap to a whopping 200 bucks
wow..i had to read that like three times just to understand it!
Hey ahhvtec you do get mad rep for that,
an also, i'm doing the same thing with a 92' Civic 4 dr.
Is most of that the same or will it be different?
should be the same since 92-95 civics are pretty much the same. one good thing about yours is 92's were pre-wired for vtec so thats one less thing youll have to do
IMO, you will have more fun with anything with a turbo in it. A b18b would have a greater horsepower potential but if you want to keep costs down then a d15 is a good choice. I just dont know if vitara pistons would fit, does anyone know for sure if they do?
d15b stock max 130 hp...turbo would definately out-do a B. I need to do some research :).
