jdm h22a 95 in accord 94
Discussion in 'HYBRID -> BA-BB /CA-CD' started by xela_127, Aug 17, 2005.
  1. tab
    tab Super Moderator
    Aberdeen, Washington State
    I'm using accord axles, with no problems. In fact, I've used axles from both LX and EX, which both have different part numbers. WHY? Because the EX has ABS, which requires markings on the outside of the spline end. It just goes to show that slight differences do make a different part number, but that doesn't mean you need to go buy a new set of axles.
    Do whatever works man, but try to use what you have first, then go buy parts.
  2. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    sorry dohcvtec accord i got a lil carried away....anyway i was talkin to some guys today and they said that there were like 4 diff combnations of jdm tranny's all same strenth and gears but the half shafts were different....didnt know that....thats probably why all of us have used diff combonations.
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Not a problem, glad we got this cleared up.
    tab needs a Superman symbol for an avatar. :D
  4. tab
    tab Super Moderator
    :D
    :headsmash:
  5. evoracer03
    evoracer03 Senior Member
    one thing i remember on this is that i ended up using an accord axle on the driver side, but i swapped the prelude inner cv to it so it would fit the intermediate shaft. as far as the prelude axles go, they are longer than the accord axles and cause binding issues if used. im positive of this on the 90-93 accords, but not 100% on 94- up.
  6. JCM
    JCM New Member
    Was really looking for help here. My little brother has a 94 Accord with a JDM H22A swap with matching trans. I replaced the passenger side CV shaft as well as the output shaft seal. I drove the car and noticed a lot of trans fluid leaked from the seal. I believe it was an Accord CV axle that I used. Should it have been the Prelude CV shaft ?? It did seem like the CV shaft was a little to short. Had play in it. I noticed someone said the prelude shaft is also longer. Is it possible that the shorter shaft is not letting the seal , seal properly ??
