JDM P73 immobilizer removal
Discussion in 'ECU's, Electronics, and Tuning' started by Magana559, Nov 9, 2008.
  1. Magana559
    Magana559 The Warden
    fresno Ca
    Well I have A Problem, I Bought A JDM P73 On Ebay And I Didnt Know It Had A Immobilizer in it So now I Need To Know How To Get it Removed.
    Planning On Running The P73 On My B16 Block With A 12:5:1 CR.
    Here Is A Pic Of My Block.
    Any Help Will Be great.
    Oh Almost Forgot, Im Going To Be Running A B16 Head......Or Any Head That I Find For now.
    Thanks,
    David
  2. Magana559
    fresno Ca
    I really need to know how to get this removed If Not I Just Lost $140.
    Will A Honda Dealer help?
  3. BrutalB83
    Rochester Hills, MI
    Very doubtful. A dealership is not even going to want to touch it...
  4. itrsleeper
    itrsleeper New Member
    i was told that jdm obd2b ecus dont run immobilizer's... (do you know what yours is like obd2 a or b) i know that for getting rid of usdm ecu's that have them you just use the factory honda mechanics diagnostic tool and then you can reset the ecu to use the "code" that your key and ignition is sending to the ecu.....pretty sure its even in the manual....well the factory honda manual...but how do you know if its the immobilizer, or if its even a real jdm ecu....check here to find out if you have what they told you
    http://hondaswap.com/ecus-electronics-tuning/decoding-ecu-serial-numbers-60510/
    here is some stuff i found, so im pretty sure if you do some looking in your area that there might be a mechanic who has one of these
    Home--Euros international commercial limited
  5. Magana559
    fresno Ca
    CRAP! I Was Sold A USDM ECU! But Then Again It Wont Fit On A USDM Harness So Thats Why He Is Sending the Other Connections.
    37820-P73-A04-1292-100055
    Here Is A Pic.
    Ill Post More Pics When it gets Here.
  6. Magana559
    fresno Ca
    Damn I Really Hope They can help me.....If Not Then Im Really Screwed :(
  7. itrsleeper
    im pretty sure you can...when we rebuilt my buddies 01 ls teg he got a diff. ecu from a diff. car and our boy came over with some kind of scan tool and reprogrammed the ecu right there at the house....so i know it can be done
  8. itrsleeper
    actually the only reason it wont fit is because it looks like you are running a obd2 a harness with a obd 2 B ecu here lookie here....i used this same ecu on my 96 ek and had to order a harness from rywire...actually its for sale....http://hondaswap.com/parts-sale-tra...ion-wheels-pistons-rods-ek-dc-etc-new-197283/...
    shameless plug! :ph34r:
    anyway good luck and i hope you figure it out:D
    OBDII ECU Connector Types
    Please note there are two types of OBDII ECU connectors (1996 and onwards vehicles) The correct type must be specified when ordering. Both type use 3 connectors (for manual transmissions).
    OBDII A
    OBDII B
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    JDM ecu are square not rectangle..so i think that is a usdm ecu
  10. Magana559
    fresno Ca
    Yep Its a USDM ECU......Ahh Crap Now I Really need To get Rid of that Darn immobilizer.
    Ill Take it into A Honda dealership And Ill Let You Guys Know What They Say......Pray For Me!
  11. Magana559
    fresno Ca
    Will Take Pics of The ECU tomorrow, Its Square So That Means Its A JDM ECU, I Talked To The Guy And he Said It Was Off A 2000 Honda ITR. :eek:
    Also Talked To Honda And They Said They Might Be Able to help Me :D
