just did a compression check?
Discussion in 'General Tech and Maintenance' started by 92egcivicls, Oct 5, 2008.
  1. 92egcivicls
    92egcivicls New Member
    just got done checking my compression on my b18b1 motor,wanted to check it before i made any real plans for the motor/car.
    #1=185,#2=190,#3=180,#4=185...
    pretty nice and even across the board,but i dont have a manual YET,to know what the limits are?
    is this withinn tolerance?can someone post the high/low limits for the b18b1.
    anythoughts,thanks steve
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    Close enough!
    Perfect is something like +/- 5psi, so you're in good shape. Those numbers are about par for any factory b18a1/b1 I've checked.
  3. awptickes
    MD
    Sounds good. I'd buy a b18b1 with that compression. That'd make a good DD.
    Not bad, but it's not good either. Sounds like it's had a medium-hard life. It'll be fine as long as you don't go F/I with it.
    Might be a good idea to rebuild it either way.
  4. SlushboxTeggy
    NJ to MA to CA
    That is better than mine.
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    Naa, still has several years in her. You aren't in rebuild territory until its off 15-20 points one way or the other. Thats still a healthy motor.
  6. 92egcivicls
    nobodys has a manual that says the low/limits for this engine?
  7. phyregod
    phyregod !!YTINASNI
    Central Texas
    From a Haynes:
    B18B1
    Standard...............................................199psi
    Minimum...............................................135psi
    Maximum Variation between cylinders....28psi
  8. 92egcivicls
    thanks thats the info i needed to know!,now can someone tell me a decent header to go with my ls swapped eg civic?i have ac and would like to keep it.and be able to line up with my current exhaust.without breaking the bank:)
