K20A2 swap need help!!
Discussion in 'HYBRID -> EG-EK / DC' started by Antweezy84, Oct 13, 2006.
  1. Antweezy84
    Antweezy84 New Member
    Cali Baby!
    im buying a 1993 EG and i would like to drop and K20A2 in it. i found a place where i can get the swap for about 6000. it comes with almost everything:complete motor, block, intake manifold, complete head, sensors, exhaust manifold, fuel rail, injectors, distributor, throttle body, alternator, starter, ignition wires, a/c compressor, power steering pump, headers, obd2 ecu, 6 speed hydraulic lsd tranny, drive shafts, intermediate shafts, enigine mounts, and shift linkage. the only thing i need is the wiring harness. i think i need custom headers too, right. is there anything else im missing. any info will help. THANX
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    oh yea you got to run new gas line hydrolic lines mounts,and a few more things i cant remeber
  3. Antweezy84
    Cali Baby!
    i got the mounts. i can have those lines custom made. thanx. if you can think of anything else. just let me know thanx again
  4. Antweezy84
    Cali Baby!
    do i use the rsx type r wiring harness?
  5. AHHVTEC
    Alabama
  6. k24hatchback
    k24hatchback New Member
    Lancaster, PA
    make sure it comes with the charging harness and at least the first o2 sensor. You will also need a five speed accord shifter box or one from a rsx will work but will be much higher. You will need a fan temp. adapter switch and also a header and mounts which were already mentioned. You will also need a adjustable fuel pressure regulator to up the pressure since the kseries doesn't run a return line but your civic does. You will also need to either buy or make custom axles.
  7. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
