ls swap
Discussion in 'HYBRID -> ED-EF / DA' started by racintweek, Mar 27, 2004.
  1. racintweek
    racintweek Senior Member
    Arlington VA
    92 ls going into 91 hatch
    isnt there a different connector to the dizzy?
  2. crx
    crx Senior Member
    cali near sac
    what model hatch? 92 ls is obd 1, you can convert the engine to obd0 by using a 90-91 dizzy and ecu. if you have a si then you can use your dizzy(top bolt only lines up) and ecu for now.
  3. racintweek
    Arlington VA
    i have 91 standard
    i have a dizzy from a 91 si
    so i just swap the teg one and the si one and it will work?
    i have all the wiring frm the si also will that help?
  4. brian11to1
    brian11to1 Senior Member
    If the 91 HB was or is an SI you can use that engien harness, just extend a few things. Use the ECU im sending you monday, and an 90-91 LS dist. I have one of those as well, I can sell for $65 + shipping
  5. racintweek
    Arlington VA
    the ls motor is going into a 91 std
    i have everything from a 91 rex si exept the body
    too rusted it was a fun demolition
    i know ive gotta do the dpfi-mpfi conv
    is there any way to use what ive got and just switch the wiring on the dizzy?
  6. brian11to1
    that distributor is designed for a SOHC motor, it will work however, it just makes more since to use one that fits properly and that's designed for that particular engine. I understand what it it's like to be on a budget. IF you cnat afford to get the distributor then you'll be alright. I was simply saying I have the dist. if you need it.
  7. racintweek
    Arlington VA
    im a broke ass mofo who doesnt know shit about this type of stuff
    trying to learn and be cheap at the same time dosent seem to be working too well
  8. brian11to1
    I understand. Im here to help in anyway I can.
