ls turbo !!!!!!!
Discussion in 'Integra' started by evilneo, Oct 26, 2009.
  1. evilneo
    evilneo New Member
    kunkletown, PA
    I haven a stock b18b1 integra motor with turbowith stock inturnals. Around what horsepower should i make on 12 lbs of boost?
  2. KDS
    KDS New Member
    do u have stock injectors and fuel pump and what do you have for a ecu
  3. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    around 12 psi, it doesn't matter lol
    post back in a week when your motor blows up
  4. greesemonkey
    greesemonkey New Member
    i agree should do no more than 8psi. with stock internals,
  5. BrutalB83
    Rochester Hills, MI
    I like to avoid making statements about how much boost any given setup can handle. There are just so many factors to consider here (condition of the engine, which turbo is being used, quality of the tuning, etc.) to really be able to provide a definitive answer. The same applies to "how much is too much boost?" It's really impossible to say "well, if you do any more then xxx PSI then your motor will blow up" without knowing anything about the condition of the engine, the tuning, the size of the turbo, whatever.
    OP, if you'd like a reasonable answer, then you need to provide more details on your setup. Still though, the only way to really know is to hit the dyno...
  6. evilneo
    evilneo New Member
    kunkletown, PA
    750 RC injectors,pr3 chipped eprom on chrome pro and stock fuel pump, and I've been running it like this for seven months now no problems
  7. evilneo
    evilneo New Member
    kunkletown, PA
    sorry pr4 typing in the dark
