ls/vtec
Discussion in 'Integra' started by 4doortype-R, Feb 22, 2007.
  1. 4doortype-R
    4doortype-R New Member
    i have 94 integra b18b1 block c1 head and leak from head gasket ge ls-vtec kit
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well that sucks
  3. tartymctang2357
    tartymctang2357 Grand High Wizard
    philadelphia
    ..... and the question here is what? you need a new head gasket it sounds
  4. brian11to1
    brian11to1 Senior Member
    its leaking from the front/transmission side isnt it? mine did it too.
    GE sends a B16 headgasket with their LSV kits. rule of thumb... you should use the headgasket that matches the block, so go buy a LS headgasket and bore out the front headstud holes so they will fit around the dowel pins.
    i had the saame exact fucking problem.
  5. marty2916
    marty2916 Junior Member
    The real problem
    There is an oil journal on the vtec head that the ls block does not have. If you do not seal this hole then the engine will leak. The solution, remove the head, take it to a machine shop and have then tap the hole shut. It will be best to replace the head gasket since your is now soaked in oil. Check the golden eagle website for the proper gasket.
  6. mac_24_seven
    mac_24_seven I trained Trogdor to pWn
    Actually, the golden eagle kit would have been ideal for you..
