LS89hatch PROBLEMS!!!!
Discussion in 'HYBRID -> ED-EF / DA' started by Goldigginghatch, May 25, 2009.
  1. Goldigginghatch
    Goldigginghatch New Member
    Bo$ton
    1st of all im a long time follower of hondaswap never had the need to post something TILL NOW that is...:mad:
    I have an obd0 LS swap everything had been working fine running strong until putting in my system i touched some wires together behind the radio and blew out some fuses no big deal... Until I left the car on for i'd say 10-15 min, and then it would conk off. I changed spark plugs, dizzy, coil,. Now yesterday after not turning it all after a week it wont turn over what Gives????:confused: I will post pics of the car tomorow. Oh and I have no intake.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    check your battery and starter
  3. Goldigginghatch
    Bo$ton
    i got a red top optima batt. So plenty of juice there i will def. check my starter tomorow im at work now. Thanks I'll let u know if that works..
  4. AHHVTEC
    Alabama
    well if the car is not even turning over its got to be that or a bad connection or fried ecu.
  5. Goldigginghatch
    Bo$ton
    Yeah i didnt think of the ecu i got it from the junkyard awhile back..
  6. Goldigginghatch
    Bo$ton
    If anyone here is selling some headers or skunk2 manifold for b18a LET ME KNOW PLEASE...
  7. AHHVTEC
    Alabama
    make a thread in the for sale want to by section. it will get looked at more
  8. Goldigginghatch
    Bo$ton
    ^Thanks man im new at posting threads so any helpful.
  9. Goldigginghatch
    Bo$ton
  10. AHHVTEC
    Alabama
    thats cool we all had to start at some time
  11. Goldigginghatch
    Bo$ton
    So, I finally had some time this weekend to work on the car. Well sord of I popped the good check the oil, goodcheck the battery connections good. I turned the key in the ignition and by some miricale it turned right on 1st time. I took ity for a spin and I noticed theres a leak from the block. I already replaced the valve cover gasket so its not that. its pretty bad because,its dripping to the exaust manifold and the heat from the actually motor is causing smoking. What do you think its coming from. Im going to take some pics so u guys can get a better idea.
  12. AHHVTEC
    Alabama
    it could be lots of things,need to try and clean it up and narrow down the area of where its coming from
  13. Goldigginghatch
    Bo$ton
    Will do.. Thanks but atleast she still turns on..:driver:
  14. Goldigginghatch
    Bo$ton
    I hardly drive her shes sitting in my drive way. I just miss her so much my daily is automatic..
  15. Goldigginghatch
    Bo$ton
    Im planning to make a trip to the track and i dont to have any problems any ideas what kind of numbers i might hope to expect.
  16. AHHVTEC
    Alabama
    im gonna say 15s 14s if your good
  17. turbo94eg
    turbo94eg New Member
    orlando fl
    clean the engine then check all the place block:driver2:
  18. Goldigginghatch
    Bo$ton
    I cleaned the engine and it turned out that the leak was coming from the cam seal. I replaced that with a golden eagle cam seal. Now the car is leaking from the oil pan more specifically the gasket. I already replaced that gasket twice. And it seems like the heat shreds it up at the seal. What do I do??
  19. dj1987nshs
    dj1987nshs DJ Cash
    Mount Airy, NC
    first off the ecu does not have anything to do with the car tuning over the starter is wired through its on relay system its sounds like a bad starter sometimes starters will work sometimes they crap out on you right before they completely go out you can get a local electric shop to rebuild it for around 70 dollars or cheaper. as for the leak you just need to clean it up like the other guy said and try to find the source if the car is still running fine the first things i would check are the oil pressure switch on the back of the block next to the knock sensor, the v-tec solenoid close to the distributor, the distributor itself can leak through the o-ring on the part that connects it to the cam or in to the cap itself. start there first.
  20. Goldigginghatch
    Bo$ton
    Thats cool about the starter, that can be but i have a ls theres not vtec solenoid... I found out where it was leaking from, the cam seal, and that oil pan gasket replaced both and its running like a champ right now exept all the old oil that spilled on the exaust manifold going to have to drive it till it burns that shit up. Than wash off wats left.:ph34r:
