Hendri
Hi guys installed the megan racing wishbones with skunk2 coilovers.Now comes the question:
The wishbones come marked left and right ,witch side is left and witch side is right.Now the problem, if from inside the car with the steering on the right the wishbone marked left installed left and the wishbone right installed right ,the caster is 0 degrees wich makes your handaling terrible in high speed cornering so wat I did was put left to right and right to left wich changed the caster to 2 degrees, handling is 100% better.
Has anyone come a cross this before.
