dilbeckskate
infamous
no its mounted on the front cross-member now behind the front bumper right next to one of the air ducts, one problem I always had with the car is because I made the oil system SOO much larger and it had a backflow preventor on the relocation part that threaded onto the block soo if the car was cut off one line and the filter are always full too prevent dry starting the engine, soooo if you check the dipstick with the car off it would always show low (because the rest is in the line and filter) soo if you filled it to the full line on the dipstick really you were over full, its about 3/4 ft of hose now and should take care of that problem soo the coil is getting mounted in its place now
