some more work before the powertrain swap.
disconnect both O2 sensors
argh rust
heat shield prevented even more rust on the nuts
the two nuts that holds the downpipe was rusted and seized. I had to use a dremel and cut off disc
the two bolts that held the flanges together just snapped off when trying to remove them.
to separate the catalytic from the downpipe looked labourous so I decided to cut the pipe instead.
general pic of the undersides
new stainless headers installed
free flow megan racing catalytic
some 12.9 grade socket caps bolts
montreal winters sigh
both O2 sensors are still good and going to be reused.
rusted out rear lower control arm
since i was underneath i notice the shifter bushing was loose and installed the prothane poly ones.
another issue i had was the freaking mounting points for the hangers was no positioned good and the line hangs a bit. Got to figure something up to lift it higher so it doesn't drag.
need to weld a hanger underneath the floor so I can use this hanger on the exhaust line.
I changed this worn bushing with the prothane one since I was under the car. LOL!!:wrench:
wanted to change this bushing and slap on the short shifter as well but seeing so much rust. I looked like it will take more than 30 minutes to do so I sprayed with it with some loose nut.
here is the bushing i needed to get to.
I will need to get shorter bolts.
as long as it does the job.
