Ok i have heard that when you tap in to the block for oil go for the adapter that goes between the block and oil filter. Or you could screw a t-fitting into the block where the oil pressure switch is but it has been known to break there because of vibration.
So i was planning on running it this way
Taking a -3an stainless steel braided line in to the block where the oil pressure switch is. Then hook up a t-fitting so i can run a oil line, the switch, and a oil pressure gauge.
Will this work?
Will this work?
