Need Aluminum Welding - Will Pay
Discussion in 'Greater Michigan' started by YBLEGAL, Jan 25, 2009.
  1. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    I need a catchcan welded up based on my blueprint. Blueprint will be provided to whomever accepts. It is no larger than a civic battery and only has a center division and baffles. Needs to be of decent quality, and hold mild pressure.
    If your interested, please let me know! This doesn't have to be local; I would pay for shipping, materials, and your time as necessary. You can respond in this thread or send me a PM.
    Some help would really be appriciated!
  2. YBLEGAL
    NW Indiana
    Bump - [​IMG]
  3. eg6sir
    if i'm not mistaken mac24seven(sp?) might do aluminum welding.. if you cant get a hold of him, try Andrew.. its his brother in law i think
  4. YBLEGAL
    NW Indiana
    No luck on mac24seven, HondaSwap Forums - Members List.
    Pointed Andrew at my thread though.
    Thanks for the heads up!
  5. eg6sir
  6. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Noted.
    I'll tell terrance to get on here for you. (He'll be on tomoorrow at work)\
    He's the guy to have it done, man. Thats what he does for a living (design alum fuel tanks / parts)
  7. eg6sir
    i knew he was good at welding... just wasnt sure if it was aluminum
  8. YBLEGAL
    NW Indiana
    Sweet. I've been trying to find someone with experience for a long while now. Random shops around me don't want to do it... and that's lame...
    I'll be checking back frequently!
  9. Andrew
    Tallahassee, FL
    Terrance doesn't actually do the welding himself. He does the blueprinting and CAD design and has it fabricated in their massive shop.
    Either way, he'll get the job done, and won't charge you $5,000 for it. :)
    1 person likes this.
  10. YBLEGAL
    NW Indiana
    Yay! lol.
    Rep given where allowed lol
  11. 97hatch
    97hatch ?
    Anderson IN
  12. eg6sir
    Andrew, didnt he make you a catch can, or was it for himself.. post some pics of the beautiness
  13. MthaFuknGreen
    Lodi, CA
  14. YBLEGAL
    NW Indiana
  15. autox 89 dx
    autox 89 dx Member
    SF bay area
    I could probly do it I'm not working right now so it could give me some thing to do. I just got laid off and and im a sheetmetal worker and I've been welding alum for the last 4 years if you want send me the drawing and ill see what I can do.Also what would you want it out of .040 or .063 ? heres a alum skylight I welded and claded in zinc
  16. mac_24_seven
    mac_24_seven I trained Trogdor to pWn
    Dude's stuff is much better though he'd probably charge more :p
    I pm'd you...
  17. YBLEGAL
    NW Indiana
    Wow nice skylight.
    Alright well I might as well post it up here publicly, then we can figure out who should or will do the job.
    I also don't know what thickness would be best. I think your judgment would be better than mine. Holds light pressure and sturdy, all it needs to be.
    I'm also listening to any critiques anyone may have with my design.
    These are just my drawings; I haven't made any architecture style drawings yet, but I need to so that they also include the bracket mounts. I'm making those up on the computer at the moment.
  18. autox 89 dx
    autox 89 dx Member
    SF bay area
    do you have the dimensions in inches?:confused:
  19. YBLEGAL
    NW Indiana
    lol I was doing all the measuring in inches at first.... then idk why decided to change lol
    Umm it's about 8in long, 3in wide, and 2.75in high. It could be done either way, the difference in size won't be an issue.
  20. YBLEGAL
    NW Indiana
    Oh I would like to add that the bottom holes are deceiving, they should have been drawn as inside as they are on the bottom for where the drain valves will go.
    Based on the center divider, each side should be separate and sealed from one another, by the way. It's 2 catch cans in 1.
