Need help for an upgrade on my integra!!!
Discussion in 'Integra' started by xtremeintegra, Jan 15, 2012.
  1. xtremeintegra
    xtremeintegra New Member
    Guys how are you i have an 99 integra GS im trying to get a turbo kit reacomendations of wich kit should do i buy??? and the engine is all stock wich modifications do i need to do to it??? thanks!!!!
  2. joker01
    joker01 Member
    caribbean, St.Lucia
    use the search button
  3. adecorzo
    adecorzo TronicsClub.com
    i been searching around for this too so far i read about buuilding the engine top to bottom pistions cam shaft all internals you can search from there
  4. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    basically, you need to do a lot of research! theres no point in us spoon feeding you. we dont even know what your goal is. you can turbo your stock engine, if you keep it conservative. and as far as engine builds... just do a lot of reading about other peoples turbo setups, see their results, and decide how much money you want to sink into it.
  5. adecorzo
    yes do alot of research also and pick a goal your want WHP wise dont set a PSI goal
