Need Help With 91 Civic
Discussion in 'HYBRID -> EG-EK / DC' started by Strahd_Zarovich, Jan 4, 2003.
  1. Strahd_Zarovich
    Strahd_Zarovich Junior Member
    I am doing a B16 into a 91 Civic Standard and was wondering if there was a place to get some info from. I checked the tech section and found nothing any Help would be nice. I know a little, but my girl really wants to do this to her car.
  2. HenryOng074
    HenryOng074 Member
    what info do you need
  3. dvsjay
    dvsjay Junior Member
    I'm new but here is what i got check it out...
    http://tech.hybridgarage.com/tech/b16/index.html
    http://www.civic4g.com/vteclow.htm
    http://www.teirney.net/civic/EngineSwapPhotos.htm
    http://www.geocities.com/extreme_vtec/swaphyst.htm
    I have a b16a1 in 89 civic hb si the intstall was pretty easy with HP motormounts and wiring harness. I had ac with it but i decided not to use it, it didn't fit right. i had a small problem with the alternator i had to bang out some the right side to get it to fit. I think it was from a integ. i also had to remove one of the fans to get it to fit in right. well good luck. hope this helps....
    Jay
