Need help with a swap??
Discussion in 'Civic and del Sol - EG and EK' started by Ek985, May 14, 2011.
  1. Ek985
    Ek985 New Member
    I got a 2000 civic automatic single cam, I'm trying to put a 95 integra automatic swap in it but dnt knw wht I need ??or can it be done?? I have the whole 95 integra car with everything !! So what should I do?
  2. RHDism
    RHDism Right Hand Drive guru
    Engine mounts/ dc to ek. (D to B series) try hasport.com or egay
    Ecu Jumper harness obd2b to obd1 (depending on which ecu )
    Possibly ek Si axels, ( Ive heard different opinions on this)
    Some engine harness differences to situate.
    The only downfall is the automatic trans. :mad:
    Good Luck..:thumbsup:
    I might be interested in your Y7or8 (old motor) if its not shot and willing to ship.
  3. Ek985
    Ek985 New Member
    Thanks bro !! I really need to knw how to wire up the tranny thts my biggest concern!! And about the Y8 I'm keeping it just in case!!
  4. MyFirstCivic
    MyFirstCivic New Member
    need assistance
    should i put a B18b1Z (intergra LS engine) into my 1996 civic coupe dx model?
  5. Ek985
    Ek985 New Member
    Come on people someone got to knw something!!
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    OBD1 -> OBD2 car, annoying, pretty sure that the tranny mount is going to be an issue, not 100% though, the wiring isn't that bad from what I remember, but then again my brain is tapioca. You'll need the swap parts from a 99-00 SI. Ideally if you could source a 99-00 SI, you'd have pretty much everything to make it a fairly painless swap.
  7. serrilion
    serrilion In my own little world! VIP
    Vermont
    I would look for an OBD2 integra, it would almost be a strait bolt in mounts, axels, ecu ect... there are plenty of autos around... where I would look... 98+ just me tho
  8. yelLOWrider
    yelLOWrider New Member
    I want to swap my b18 motor but i am not sure what to swap with, it's a 1990 Integra. Any suggestions?
  9. xj0hnx
    C.C.TX.
    Start with a thread that's not three months old, then move on to the correct category, once you've done that then swap in your own thread.
