Need Help with my Gsr A1 Ls vtec swap
Discussion in 'Integra' started by DrAy, Jan 8, 2007.
  1. DrAy
    DrAy New Member
    Hey all iam a new member here. K this is what i need help with, i have a 2000 civic si and i am trying to put a 1990 Gsr A1 Ls vtec in to it.
    This is how the engine is built. I got a
    1990 block
    99 si head
    scunk 2 headers
    H22 injecters
    b17 tranny
    so the problem is the wireing is different from the my civic si.
    if any one done this kind of swap before, what do i need to do to get the car up and running.
    Any little help would be great.^_^
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    What harness are you running.
    Getting that tranny to work is going to be a bitch because it is cable and your car is hydraulic. I would go with a diffrent transmission for sure.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    as long as your useing the 99 si head all you have to do is drop it in and plug it up, and just for a note there was no 90 modle gsr they didnt come out untill 92:D
  4. DrAy
    DrAy New Member
    well iam not sure what kind of wire harness i am useing but it dos not hook up to my Si wireing.And what kind or tranny do you prefer?
  5. AHHVTEC
    Alabama
    if your car is a 2000 si were is the stock harness
  6. welfare
    welfare Ancient Member
    New York
    if your car is a 2000 si, where is your stock tranny?
  7. DrAy
    DrAy New Member
    The shell what stripped and the engine was missing and all the wireing
  8. hazzardboy95
    hazzardboy95 Hon-daaaa
    Pasadena, Md
    Wow, that blows. How much was the shell, tell me free!
  9. DrAy
    DrAy New Member
    no i didnt get it for free it cost me 1500.
    By the way can any one tell me what tranny will fit my b18A1
  10. DrAy
    DrAy New Member
    no i dont get if for free i paid 1500 for it.
    by the way can any one tell me what tranny will work with my engine.
  11. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Any 94-2000 b16 or b18 transmission will work in your car. Get a stock 1999 or 2000 Civic Si or Ex harness off ebay, and you should be good if you are using a 2000 Si head like you say.
  12. 801CRX
    801CRX Got Rice?
    UTAH
    Any B-series hydraulic tranny.
    And then get a wiring harness that is the same make and model of your head.
  13. DrAy
    DrAy New Member
    K thanks alot every one ill get back to say how it went... :) :) :) :mellow: :mellow: :) :)
  14. jubbeng
    jubbeng New Member
    hey dude u can still use the cable tranny
  15. jubbeng
    jubbeng New Member
    u will have to use your master cylinder to push the cable clutch lever
    its a pretty ok conversion
  16. welfare
    New York
    The conversion sucks ass, I used it for about 1 year on my civic/ys1 tranny, the position of the slave cyl on the tranny with the kit installed makes it so that water gets trapped in the bore of the cylinder causing pre-mature failure, in 1 year I went through 2 brand new slave cylinders plus the original one.
    I would only recommend this if you arent gong to drive the car in the rain or on wet roads, or if you really can't find a hydro tranny and all you have is a cable.
    Its not worth it to have to put in a new slave cyl every 4 months.
    1 person likes this.
  17. DrAy
    DrAy New Member
    Thanks for your help but i already bought a b16a2 tranny and an 2000 wire harness:) :) ^_^ :) :)
