gasnmyveins
Hi, everybody. I've done a lot of work on other cars in the past, but the most I've done to my 1990 crx HF is taking off the valve cover and adjusting the valves.
I've developed a very bad water leak. The car is up on jackstands right now. I refilled the radiator and it started to leak from the driver side of the engine. I went under the car to see where it's coming from. It's dripping from a bolt right next to the alternator, but it SEEMS to be coming from somewhere above that and running along the edge of the plastic cover, then running over to that bolt where it starts to drip.
My first thought was, "Wonderful, a head gasket." I checked the oil, and thankfully there is no water in it.
Any ideas? Thanks for the help, Don.
