"each motor/car is different and your results may vary"
But check out this site cuz they do a lot of comparisons and it might help answer your question. Click Here.
I can only tell you what I'm planning on getting. I'm supposed to pick them up this week, CTR header w/ flange. But any 4-1 design header should be a good choice. If you go oem Honda make sure you get the heat shields and the flange so it bolts right up and it looks stock. If you're going aftermarket make sure it is 50-state legal incase you get pulled over.
Originally posted by HOOKUPSPROCRX@Mar 26 2003, 11:11 PM i agree that every motor is different but we have had a lot of luck with the JDM ctr header on b16a's. pluse looks stock
