need some help im new...
Discussion in 'HYBRID -> EG-EK / DC' started by SgregVanliewC, Apr 9, 2007.
  1. SgregVanliewC
    SgregVanliewC New Member
    Hey i have a 1999 civic ex automatic. my friend has a 93 or 94 Ls integra with what i think would be all the things i need for a swap, but my question is do i need anything els that i dont have on my car (cus its an auto) that i would have to get from say a five speed civic? try and be easy on me i dont want to get flamed for trying to learn
  2. SgregVanliewC
    anyone??
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    The differences between the 93 and 94 Integra make your questions hard to answer.
    If it's 94, take the swap with shift linkage, pedal assembly, clutch master cylinder and learn how to do an Auto to Manual conversion.
  4. SgregVanliewC
    hey thanks for the reply...its a 94, and i have basically figured everything out except what i should use for axles, by any chance do you know what i can use?
  5. SgregVanliewC
    over at the tech someone told me that i will need a ek pedal ass. and ek hydro clutch lines.. along with the rear si trani mount which i knew already but i figured that the teg one would suffice, guess not, im goin to a salvage yard this weekend any suggestions on what i should look for? thanks in advance for the help
  6. VTECin5th
    Phoenix Az
    I'm not positive if the integra pedal assy will work on a 96-2000 civic, so it'd be best to get the EK pedal assy just to be sure.
    94+ integra or 99-00 civic Si axles will work fine.
    You will need the Si rear and Si driver's side mount brackets.
  7. SgregVanliewC
    once i have everything i need (pedals and lines) im gonna get this mount kit from enjo racing, im guessing this has the trani mounts i need. but im not sure. sorry for all the questions but im just trying to eliminate most of the little problems i might run into
  8. VTECin5th
    Phoenix Az
    I'm not sure either, I've only read and heard of the aftermarket tranny mount being required. Good luck though.
