ricerburner
ok i got an 88-91 crx lined possibly. when i get it im wanting to do a b16a swap with the LSD tranny. i plan on turboing it after a while. im planning on running a t4 turbo with 10-15psi. im gonna get an AFC, 550cc injectors, high flow fuel rail, 255 fuel pump, arp studs, 38mm wastegate, stage 4 clutch, intercooler, bov, 3in downpipe, some cams, header, and a flywheel. my question is what kinda cams should i run? where can i find some? and what kinda head gasket would be the best?? i seen on a forum about a head gasket that will lower the compression to 9:1. can i run 10-15psi on stock internals or no?? any help would be nice. thanks
