04 azure mach
i have a 95 accord that died while driving. so far i have changed the timing belts,tensioners,water pump, fuel filter, plugs,wires,and distributor but i still have no spark. any help would be appreciated.
Good you found it bro! Reading down through what had been done and advised, I was going to send you after fuse boxes and fuses.so. after going back and rechecking every thing for the 30th time i finally found the issue! i went back and pulled the carpet up and was looking at the ecm and noticed one of the plugs going in was a little corroded. took a little file and cleaned it up and the car fired up perfectly. aint that a bitch. thanks for the help
