well i still have all the mounts off the old engine and all D series are the same from what i was toldd.butt then again i was told this swapp would bolt upp but im running into promblems..like on the obd0 harness there these two little yellow wires it went to a sensor i think on the old motor but noww i dont find the same sensor on the b7..if any one know what im talkin about please help..
I found out what ima doo!!
ima keep it dpfi for now then ill do the dpfi to mpfi swap when i get my new ecu and vtec head
but i was toldd i can keep the 90-91 auto ecu because i swap auto to manual (what a bitch!!), tthe car will run finee but it will throw the check engine light..?
