Oil flow / restriction / feed????
Discussion in 'Forced Induction' started by smooth_criminal, Aug 23, 2005.
  1. smooth_criminal
    smooth_criminal Senior Member
    So when i get on the gas really hard my turbo starts to smoke and smells like oil. I'm running an 18G and the stock greddy oil feed line / banjo fitting. Should i put a restictor in the line? i know this is posted a few posts down but it's not descritive enough, I just got the turbo rebuilt and i know the seals are fine, but i'm thinking it's getting to much oil. Right now i have a -3an line running fromt he block to the fire wall, brass T's on the fire wall with the stock greddy line running runing from that, my oil pressure is reading like 80 PSI at WOT, let me know what you guys think, I'm running like a -10 an return line, but i think the center of the turbo is filling with oil to fast.
  2. pissedoffsol
    -3 feed, -10 feturn is fine.
    but, how is the return routed back into the pan.... that may be the culprit.
  3. smooth_criminal
    i just redid the return, It's 100% straight down, I just think i'm getting to much oil feeding into the turbo, so i'm goign to order a restrictor. Maybe that will help out. Becuase it smokes like a mofo at WOT.
  4. pissedoffsol
    where is you pan tapped?
  5. smooth_criminal
    All the way up top right under the turbo, it's on the small side of the pan, the dip stick inserts right infront of it, I'm showing 80 psi at WOT so i think thats the problem.
  6. pissedoffsol
    80 psi is normal for WOT at the oil pressure sender.
  7. smooth_criminal
    the i don't know what the problem could be, it's fine as long as i don't get on it, but once i get on it, it's like the oil isn't drianing fast enought and smoking / burning. looks like it's coming off the DP but i can't tell. I'm going to jack it up tonight and see if it's leaking or somthing because i do see a few oil spots under my car when i park.
  8. pissedoffsol
    yeah, your return spot isn't ideal either. it should be at the top of the deep part by the timing belt side, about an inch in. from the right if you're looking at the bay...
    this is a v8 pan or some shti, but it will work for explaination...
    on the top of the picture... in between the1st and 2nd dot in is where it should be.
    going clockwqise... 12" mark, dot dot on the bend, dot 1 bung dot 2.
    make sense?
  9. smooth_criminal
    yeah i got ya, i'm either going to order a new oil pan (happen to have one?) Or get a mosmo pan.
  10. pissedoffsol
    sorry, don't have an ls pan
