oil light
Discussion in 'Accord' started by rookscr, Sep 15, 2011.
  1. rookscr
    rookscr New Member
    when driving when it feekls like it my oil light comes on and just blinks. its a 94 dx accord. it dont leak or burn a drop of oil and its never low so i dont understand the light. if i shut the car off and turn it back on the light goes off and stays off untill it feels like blinking again. any ideas?
  2. rookscr
    rookscr New Member
    feels
  3. lurch
    lurch New Member
    I am not 100% but you might want to look in to an oil pump. Like i said i could be wrong.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Check your oil level. How long has it been since you changed it? Pump could be going out, something is causing it to see less pressure, or think that it is.
  5. rookscr
    rookscr New Member
    its always full. always change it on time.
  6. rookscr
    rookscr New Member
    could it be the oil pressure sensor?
  7. rookscr
    rookscr New Member
    really? no one knows? i stumped everyone? now i really am screwed.
  8. TurboMirage
    sure could be the OPS. and cheap to replace too...
  9. xj0hnx
    C.C.TX.
    It's been a month and you haven't ruled out the switch?
  10. rookscr
    rookscr New Member
    i put in a new one right after that post. same thing still happens. but now the same kind of thing is happining with the fuel pump. seems like it gets hot and dont want to work. and its brand new
  11. xj0hnx
    C.C.TX.
    Do you have an after market alarm?
  12. rookscr
    rookscr New Member
    nope. no power nothing either windows, door locks, not even cruise control.
  13. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    Try some 10w50 oil..
  14. rookscr
    rookscr New Member
    its got 10 40 in it now. i think its just a wacked electrical system. the fuel pump is all janky too. so who knows.
  15. CDelgado
    CDelgado New Member
    Derwood,Maryland
    Have you checked the oil pump gasket or oil pump itself? Mine did this and it was just the gasket luckily
  16. 78civic
    78civic Junior Member
    NW MS, Y'all
    the wires sometimes get brittle and break exposing wires. Check the sensor wire to see if it's grounding somewhere..
    If your mechanical, rig up a brass/alum block with threaded ports for a grease gun on one side and the threading for the sensor on the other. Hook a multi-meter to it and pump away. THe grease shouldn't pump up into the sensor, well, nothing that a little carb cleaner jet nozzle won't clean out. (HEY! THAT SHOULD BE A STICKY.. GLAD I THOUGHT IT UP)
    Does the sensor make continuity?
    Does it jump around? (the reading)
    Just for the heck of it, stick a pipe cleaner in there a little bit to see if you have clogged arteries.
    E
