What do you mean, you didn't buy any of your lines with the golden eagle kit? You'll have to deal with whatever they gave you. You need to find out what size the output lines are on the adapter, you can take it to a hardware store and goto the fittings section. Find a "flare fitting" (If I rememeber right) that fits, and then you can match that to what you need to buy in a SS line, that way you don't buy one that wont go...
It could be as simple as getting a kit without a block fitting, but you have to make sure to match the sizes to what you have, or get an adapter of some sort. I don't know how many sizes are out there becuase I have only 1... I bet there are 2 or 3 though, just enough to screw up your luck.
HTH
