ok im getting pissed. im trying to move my installation onto another drive. mainly because im consolidating my OS's onto 1 640GB drive. rather than 2 320GB drives. this saves space and cable mess because the 320s are IDE and the 640 is SATA.
anyway. when i install server 2008 onto the new drive and try to activate it. it tells me that the key is already activated. duh ive installed it before, but i want it on the new drive. ive called about 5 different 800 numbers to call microsoft and get nothing but the run around and eventually a "disconnected" call. ive tried making a drive image to copy the activated installation over to another drive and thats not working either, im using DriveImage XML but every time it says that the VSS service is not running (although it is) and it says that it cannot continue byt the image may be damaged. when it completes, sure enough it wont load up into windows.
any suggestions either on how to get windows to activate on this new drive, or a GOOD drive imaging software to use thats free so i can just copy everything over to the new drive.
