I am trying to find out as much info about the knock sensor wiring into my VTEC wired EG hatch. I DO NOT have the old D series VTEC ECU anymore (had an LS before and sold the old 1.6 SOHC VTEC motor 10 yrs ago)
I have been searching but need confirmation of some sort.
The Knock Sensor wire is red/yellow?
The wire needs to be ran through firewall and connected? To the wire plug in the kick panel? D3??? Is there a way to SECURE it to the clip and make it as solid as stock would have been if it was wired with knock sensor
Also heard that you could tap into another wire and make it work that way? If so....which wire do you piggy back on?
Any help would be greatly appreciated. If you don't know....but know someone who might...please ask them.
Honda baby!!
CAFROG
Honda baby!!
CAFROG
